Search the forum,
Discuss plastic enclosure in the Australia area at ElectriciansForums.net
hi all
just wired a lighting circuit and had 6 cables (feed,wall light x2,wall light switch,centre light, centre light switch ) to connect in a enclosure, i just used a plastic double backbox, and blank plate for the enclosure which was a bit time consuming,
can anyone recommend some decent plastic enclosures for use with wago's which accept cables from all sides
cheers
I was going to suggest Gewiss with DIN rail mounted Wagos; what kind of location will it be sited in and how aesthetically pleasing does it need to be?
If in a house I would have probably gone for a 47mm backbox and a double blank to go with the rest of the accessories, like you've done.
Reply to plastic enclosure in the Australia area at ElectriciansForums.net
Hi, I've done some work in a house, I used an existing 10mm cable on a B40 MCB to supply a 2 way consumer unit to control a heat pump and...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi, I have a client with a small caravan site, approx 5 hookups. His old toilet block was nothing much more than an old shed. He's now 'upgraded'...
Not the usual per-1966 sort of "no CPC in wiring issue" but plastic light switches in plastic back-boxes in trunking wired in singles. The lights...
A house we have just re-wired has one of these cooker points, Trouble is the kitchen wasn't supposed to have been touched by any trade but...
