Discuss Plastic trunking over a door way in the UK Electrical Forum area at ElectriciansForums.net
pc1966
The use of fire-resistant clips to avoid premature collapse of cables is obviously a good thing, but what about when the cables are in plastic (PVC-U) trunking that offers metal clips for this reason. The reason for asking is I am looking at some options just now (Marshall-Tufflex Mono Plus 20) and it claims:
  • Suitable for dado application
  • Self extinguishing and non-flame propagating PVC-U
  • Fire clips available to secure cables within trunking and prevent premature collapse in the event of a fire
Is there something I am missing as in the event of a fire I would assume the PVC trunking would simply melt and the clips would be useless?
TL;DR: Is plastic trunking with metal clips OK above a doorway?
Are the metal retaining clips part of the fixing system of the trunking?
I'm not sure. I think they simply push in to keep the wires within the trunking if the front is removed:
[automerge]1590244010[/automerge]
You secure the clips though the trucking into the wall so the idea is the trucking melts away and just the clips remain holding the cables in place.
Looking at them perhaps a screw could go through the spring loop, but it is not really explained anywhere I have seen so far.
[automerge]1590244248[/automerge]
Yes, @Flanders is correct, I found a separate data sheet showing them being screwed through.
[automerge]1590244409[/automerge]
Unfortunately going through that data sheet they only do clips for the middle compartment on that style of trunking so it can't be used as a separate-compartment style if fire cable collapse needs to be considered. Doh!
The ones you have picked do go in the middle but looking at the catalogue there are different ones for the top and bottom compartments
The clip surely must be attached the wall
[automerge]1590245356[/automerge]
Makes you wonder why we bother with plastic Mini trunking and simply don’t Just p clip everything Surface instead
Reply to Plastic trunking over a door way in the UK Electrical Forum area at ElectriciansForums.net
I'm a bit out of touch re 18th edition. Is it really necessary to fit loads of additional metal saddles inside trunking when it's only 400mm...
Hi. I am planing on building a (not sure what to call it) U shaped storage solution which goes either side and above the headboard of a bed. I...
4K
  • Locked
5K
Just wondering how your guys observe the reg, for preventing premature collapse of cables in plastic trunking, when securing to plasterboard, i.e...
4K
Hi all Recently my company (I'm just an employee) moved into a new unit and have installed some shelving, the BigDug kind. We've had plug sockets...
Deleted member 105166
