Discuss plastic wire gauge - mm in the Electrical Tools and Products area at ElectriciansForums.net
gazdkw82
I seen somewhere not so long ago a plastic credit card size wire gauge. It had all different sized cut outs in it so you could offer up a conductor in order to correctly size it. cant find anything decent that's measured in mm.
Its just to quickly size a conductor if in doubt
make your own from a bit of metalplate' . calculate the diameter using A = Π Γ²
That one I linked to, I'm pretty sure that is giving the diameters, rather than the CSA.
You'd need to work it out differently for stranded if you make your own.
Do you have some digital calipers?
yeh I have some.
Then just make a table to print out of CSA & diameter and use the calipers to check.
I can upload the xlsx file if you want it to make it look prettier or change it about a bit.
Reply to plastic wire gauge - mm in the Electrical Tools and Products area at ElectriciansForums.net
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
Disclaimer: I'm not going to attempt this job myself, I want a professional to do this job properly since I consider it non-trivial and need it...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
