Discuss Please help switches keep melting. in the Auto Electrician Forum area at ElectriciansForums.net
Rhodey
Sorry if this is long winded but I need help figuring out the electrics on a go kart I've built the kids.
It's a 24v 240w motor powered by 2 12v 7ah SLA batteries wired in series, 24v speed controller brought from ebay, 6 pin forward / reverse switch, cordless drill trigger attached to foot pedal for throttle. The go kart works fine apart from keeps melting the 6 pin switch and throttle switch. I used about 4 different makes models but keep melting even though there rated at 16a which I thought would be enough.
Electrics baffle me so as basic explanation as possible please, my late father was an electrician so he would sort it for me normally but now I don't know where to go.
Is the a device I can put in the circuit that can limit the amps to stop the melting issue.
Simply 240W divided by 24V is 10A....
however, to get a motor running, the start up current could be 3 times that.
Thanks for the reply, would a relay work? I can find the same switches capable of 30a.
I've tried looking up the answers on Internet and other forums but people seem to relish in replying with technical answers as to prove a point they know and I don't etc.
As per littlespark, starting currents will be well over 10A. Also are the switches rated for DC? switching DC is much harder on a switch than AC. In addition a motor is inductive this means that there could be higher voltages at switch off which could cause arcing at the switch. A 30A DC relay sounds much more suitable to me.
Can you post a sketch of the wiring? If there is a speed controller involved then I would not expect the switch to be switching the main motor load.
It should be simply commanding the speed controller to run.
So the potentiometer is linked to the throttle pedal right? Why is there a throttle switch in the feed to the motor?
Great idea building the go kart by the way!
i can understand the sketch.
have you any instructions for the controller?
if not, can you send some pics of the control terminals?
presumably 3 are used for the speed potentiometer.
are there any others? especially interested in any that have a link wire between them.
I'm with you now, sorry. I thought the potentiometer was the throttle control. I missed the bit where you said it was to limit maximum speed.
i think the pot is attached to the pedal to act as throttle, with a switch to enable power to motor??
i didnt think it was a seperate max speed limit pot.
Some more picutes all made from scrap parts. The steering the bits from a mobility scooter, wheels from old bikes, the steering wheel is a pulley from a washing machine. Cost me about £29 so far.
I think its great, hope we can help in getting it working for you.
I thought that. But read post #10. I think the pot is additional to the throttle.
All made from scrap parts I had, the steering wheel is a pulley from a washing machine, old bikes etc cost me about £29 so far.
[automerge]1593547678[/automerge]
The pot limits overall speed and the throttle pedal was just an on off switch really.
Reply to Please help switches keep melting. in the Auto Electrician Forum area at ElectriciansForums.net
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
I am in a bit of a pinch at the moment and trying to argue a massive amount of used of electricity with my provider which I find it hard to...
Evening All Please go easy on me as I am new to this and attempting to do this myself. 😬 I am currently building an outhouse at the back of my...
Hi all please could someone help, my ovens keep tripping the rcd see images for details basically from the cu I have 63 amp rcd with a 32 amp mcb...
Hi all, I hope you can help me please. I had solar system installed nearly 2 months ago and my installer turned out to be cowboy despite having...
5K
