Discuss PME earth "disconnect gadget" in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
UKPN
I understand there is a gadget on the market to disconnect PME bonding. I/We are quite concerned about this and I would be grateful if a member could quote the Regulation number for this. Thanks in advance.
Regards, UKPN
There are boxes like the Matt:E and smilier for EV charges that disconnect E as well as L&N, but presumably this is some other gadget you have heard of?
Reply to PME earth "disconnect gadget" in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
After conducting a recent EICR I found among other things that the Galvanised columns in the carpark area of this premises seem to be connected...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
I've wired some cable to a small 3x3 shed with 2 gpos, a 15a GPO, and a light. The shed is about 2m away from the house on a concrete slab. The...
