Discuss Possible boiler conflict in the Central Heating Systems area at ElectriciansForums.net
I would just like to thank needasparks and Chris Murphy, for a very interesting question and answer. I must admit I don't know if I would have thought of possible problems caused by fitting a fan in the same room as a boiler in that type of situation. Just goes to show you never stop learning, and I will certainly be thinking of it from now.
Ditto what others have said, can't really add to that, they said it all.
Thanks again guys, great help.
"Hello needasparks",
What did You decide to do regarding the Surveyor / Installing the Extract Fan - regarding the possibility of the `Cross Ventilation` of the Boiler Compartment - ?
Regards,
Chris
At the time i was waiting for replies so had to make an educated guess on the spot so stuck to my first post that i did not know enough information on the boiler system fitted and that I was not able to install a fan until information was provided that the boiler would be safe in its location. this was passed to the council surveyor. This was obviously before the information you guys gave me but am sticking to it as although I trust what has been mentioned and with no disrespect but me saying as a sparks thats its ok now because the blokes on the internet said so does not promote confidence. I see it as i have highlighted a possible problem and hopefully the so called surveyor will look closer at this and other jobs a little better, if i have to go back and fit the fan so be it, i've not lost a thing.
Makes you wonder how many of these installs have been done without this regard even though this time it was not a problem, as i earlier said i'm no expert on heating systems but i always do look at possible conflicting items relating to my installs. I guess if i had not had a good teacher many years ago i would not have given it a second thought but it happend once and was pointed out to me and i have never forgotten it but to be fair that was many years ago and boilers have moved on and left me behind but to me it just looked an old style.
"Hello again needasparks",
You definitely have the correct attitude about this - Including NOT deciding to go ahead with the installation of the Extract Fan in these circumstances - even after finding out that the Gas Water Heater is a Room Sealed Appliance.
I congratulate You on your Professionalism and regard to Gas Safety / Gas Regulations.
My entire reason for going into so much detail about the circumstances of the Water Heater Compartment and the `Cross Ventilation` of that Compartment was to prompt You to notify the Surveyor about this - You will remember that I advised that one a couple of occasions.
I am sure that You noticed that at no point was I advising You that because the Water Heater was found to be a Room Sealed Appliance - and therefore the Flue would NOT be affected by the installation of the Extract Fan - You should just `go ahead` and install the Extract Fan.
That is why I then let You know about the Compartment Ventilation Issues.
Regards,
Chris
Reply to Possible boiler conflict in the Central Heating Systems area at ElectriciansForums.net
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
hi ive got an unused isolator in my airing cupboard that use to run a shower. no longer have has have combi boiler feeding a new shower. the...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
