Discuss Power Jack 12 volt LF inverter in the UK Electrical Forum area at ElectriciansForums.net
I bought Power Jack 12 volt LF inverter few years back, Can I modify this inverter to 24 V or better 48 V inverter? Possible???
Sorry, not realistically. All the main DC side power components - the transformer, transistors and capacitors - will be specific to the 12V configuration and changing them would involve re-engineering the whole unit.
Reply to Power Jack 12 volt LF inverter in the UK Electrical Forum area at ElectriciansForums.net
Hi got a 8 panel solar system on bungalow, changing the board to 18th edition spd board Solar feed is chased into wall so will this need a type B...
Hello, So I purchased a Novopal 2000w/4000w(Peak) Pure Sine Wave Inverter DC 12V to 110V/120V. I purchased this so I can hook it up directly to...
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
I want to connect one panel 12 volts (south west) with 2 panel that are in series 24 volts (south) in parallel to a 24 volts in controller. The...
I am a retired Electrician and started looking at Solar Power, (Black Magic to me), after much reading of "How To", I decided to build myself a...
