Just fitting a new board for customer as they want a shower installed, bathroom company says their electrician is not available and have asked me to quote for the electrics, what is the going rate for this?
It's a bungalow and only a 5 meter run, the plumber is chasing the walls for the pipe work and they will re-decorate once completed.
Thanks.
I usually find price of materials provided + (how long it will take* your hourly rate?)+ materials mark up+ fuel cost = cost of job, that works wonderfully well for pricing jobs
I have worked out a price but just want to get a idea for labour rates, as don't wanna overcharge hoping I may get more work from them.
£150 + materials is about right, but if you are fitting a new DB/CU, you could maybe do it a bit less as you're already there.
Thanks telectrix,
I was going in about £80 plus materials as it's only a short run and no more than a 2 hours work and I was fitting the CU anyway.
Yes I agree with Murdoch, you don't want to be setting a presidence that will cost you money in the long run. If you do this one cheap they will want every other one cheap.
As usual Tel's spot on. Ive charged over 300 for that sort of job but much longer run, etc etc.
just a normal job- Tel's post
Ps it might only seem a " couple of hours" but what will you do for the other 2.
1/2 a day! Probably more as you will need two trips, 1st fix/2nd
You have to consider you are not only charging for your time but also your expertise, certification and notification.
i say it now, want it done right with we piece of paper saying done right then thats what it costs... if someone is saying you buy material+ tenner then thats what your getting, a tenners worth. but hey ho ho ho
I'm on site with a long list of jobs the customer wants done before they move in, one of the jobs is a CU replacement.
The CU is mounted just below the ceiling. The run is just across the hallway (clipped direct) in the loft as this is a bungalow, bathroom fitters will chase wall and I will do final connection and I'm onsite anway.
Will take 15 mins to bang in a dozen clips and leave cables ready in loft for first fix and 30 mins for second fix and testing, charge 2 hours @ £40 a hour plus materials. Is this still to cheap?
