Discuss protection for meter tails in the UK Electrical Forum area at ElectriciansForums.net
Sb8389
Hi guys,
I have consumer unit to change and i need to change the meter tails.
The setup is the meter box outside and the consumer unit is high level in the kitchen,the meter tails are presently run up the out side wall about two metres then through the wall to the consumer unit with minimal protection to them apart from about a metres worth of capping.
If i install new meter tails what protection will i need to protect them.
Any ideas on what would would look the best.
Reply to protection for meter tails in the UK Electrical Forum area at ElectriciansForums.net
Client needs an SPD fitting but no room in c/u or adjacent. Best bet looks like a parallel connection into the tail blocks in the meter cabinet...
Client has had a meter installed for a new consumer unit in their shop they are looking to rent out the spare space for a barber shop so they want...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hi folks, I have recently had a 5kW Solis inverter and 15kW/hr of batteries installed. Everything is working fine, but I have some concerns about...
On a new build site how/ why are people getting away with installing meter tails over 3metres in length and behind dot and dabbed walls with no...
