I was always told that things like liquid soap and washing up liquid can degrade pvc over time. Don't know how true that is though.
Think that was always a bit of a myth, and especially on modern PVC. No what it did was when it solidified it became just a horrible gooey mess
Nylon draw wire for 20mm, for larger sizes we use something which looks like a bit of curtain wire, or some polythene plumbing pipe, although it is imperative to wear safety specs as I found out to my peril when it sprung back and hit me in the eye once.
For big bunches of cables or where the conduit is getting full, rub a load of monkey spunk around the cables, maybe squirt some in the end of the tube.
If you tape bunches of singles together at regular intervals (around 6 inches) it stops them tangling and snagging quite so much.
When pulling go for the softly-softly approach - 'pull-a-pull-a-pull-a' rather than yanking the draw wire as hard as you can which usually just pulls it off the cables.
Bits of lads ............................you should be able to tow a caravan that is hitched to a truck that is pulling a container with a joint ..................so my old sparks use to tell me.
I find that staggering the cables onto the draw tape works well. Using ideal industries- aqua gel (cable lube) works wonders, as does designing the conduit well in the first place.
If i know im going to have a tight run, then i pull all the cbales through that peice of conduit at once.
i was told u can use a hammer to tap the conduit if the start to bcome slow to pull. the vibrations get them moving again.
Didnt think you could have more than 2 90 degree bends without a drawing in box.
yellow 77, ....
The metal spring could, in very unlucky circumstance find its way into a live board..
Ive always been taught not to tape together cables, but Ive never had to draw a single one back through again so Im not sure on that.
Never really had a problem, I mean how long are these conduit runs from trunking....?
Correctly sized tubing, tie/tape them on tight, plenty of lubrication and it is essential that on long/tighter pulls that you have someone feeding in the cables as you pull from the other end.
Gently bently does the trick. One at each end feeding/pulling.
I’ve always used French chalk as the lubricant, but I’m old(ish). It’s a hangover from pulling VIR’s in.
Would talc count as a similar method to chalk Tony?
Worked for a well known contractor once and they wouldnt buy pulling lube (too dear) so used lard instead,one day local shop had none so gaffer used a spray something like wd40, later on when megging out all cables were down on this particular circuit.when I pulled the cables out all the insulation was melted on the run where he had sprayed them,whatever it was it sure made a mess I often wonder if the place smells like a chippy when the cables get warm.
That sounds like it's asking for trouble - presumably monkey spunk has no nutritional value, whereas I bet the mice love a lard-coated cable. It probably doesn't help prevent the spread of fire either.
Yes it would.
I could get French chalk from stores, talc would get funny looks from the store man.
We could get athletes foot power from stores, I’ve used that at a push.
If you use powdered chalk that's sold for the old fashioned chalk line it comes in a plastic bottle with a little pointy spout so you can squirt it into the conduit as the cable or wires get pulled in.
highspark,
Engineer54,
