Discuss Putting a chandlier up in the Lighting Forum area at ElectriciansForums.net
Hi guys
I need to put a chandlier in my siblings house.
I've taken the old one off. As you can see in the pic.
To put the bracket on do I just make holes in the ceiling white bit.. Or do I need to rip white bit off as the previous bracket was too small and the hole you can see is too small .
Also what kind of drill bit shall I use to make the hole?
The bracket should be placed on the underside of the white painted ceiling.
40mm woodscrews should be screwed into any solid wood part of the ceiling.
This should be enough for a light weight light.
Anything really heavy should really be fitted by a professional.
Depends entirely on the fixing bracket that's supplied but generally speaking it looks likely that the standard style saddle bracket will span that hole and cover it over when the base gets screwed on - so you'd want to use a couple of decent sized self-tap woodscrews to screw straight into the joist, no drill required.
What’s the bracket look like? You should be able to secure it straight into that joist for a good solid fix.
The hole in the ceiling is too small to get to the wood bit...so I'll have to either drill on the white ceiling.
Or I have to make the hole bigger.
Which one will be best to do ?
The wood seen in the photo is not a joist, but a piece of wood lath. There may be a joist above.
This is the wood.
Is I need to cu into the white bit to make the hole bigger.
Which side would it be better ro start cutting through ?
Reply to Putting a chandlier up in the Lighting Forum area at ElectriciansForums.net
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Hi All, Might be a stupid question but I have about 30 of these smart+guard alarmed call point covers to deal with. All the batteries are dead...
A friend of mine is looking to have an electric shower fitted and has floorboards up already (mostly, long story). Anyway there is a run of 2.5mm...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
