OK, some good advice on here to help me try a few things. So I turned off and had a look and pressed any button that looked like it could reset, nothing obvious. Then I notice the second thermostat, I think that is an override one, I adjusted the temp on that, but that should not make the difference as it worked before.
Then I flipped the clamp to trick it into daytime and it fired up! odd. First sent 85w then went higher...obviously because it was drawing power itself and increased to suite etc. Went up to 2.7kw. So I've flipped it back and will check tomorrow night to see if it has drawn anything from daytime.
Yah, so it is working as it should. Chances are it hasn't been working recently due to a lack of export, the weather is starting to change and days are shortening. Also you mentioned an EV charger, if this has been on during the day to tie in with the solar, then export will be significantly lower.
I hear what you are saying, but last sat was a very sunny day and it was doing nowt with energy going back into the grid. Maybe I managed to reset something, I did not notice any of the push out switches 'out', but there are 1 on each of the poles for the element, they both seemed 'in'. The second thermostat clicked a little bit when I pushed in the actual dial for temperature and the thermostat has a very small push in so I pushed that too. Maybe one of them had tripped out somehow, with all my fiddly. Anyhoo, I will check properly during the daylight this weekend and report back.
Once again, thanks for the support, sometimes, you just need a lot of suggestions. 2 minds better than 1 and all that.
OK, after some testing and trialing. I believe it's a communication error from the wireless sender to the box. It will not sync every time and I have to turn it off and on again for it to sometimes work. I have asked the supplier to send me a higher range version (even though I have a clear line of sight at approx 10m), the one with the kit should cover 20m, the one they are sending 40m! So I'll test this one next. Most frustrating as I'm wasting all that sun :)
Hello,
I am new in this Forum, because I'm French. I had the same issue as STYLERUK.
I had contacted him, and his answer was that the unit was faulty.
As I bought an used PV Mate, I wasn't able to send it back to the supplier. So I tried to repair it, and I succeed.
The TRIAC BTA10-600 was faulty.
You can test if the Triac is faulty, event if you don't have the right one. You have to connect correctly A1/A2 and the gate.
Thanks for your Forum.
Hey styler, how did you get on after the thread died down, i found this by searching for pvmate-immersion related problem and have basically a similar problem where the pvmate sensor collar is fitted correctly and is triggering the pvmate immersion controller to start up when excess pv elec power goes to the grid, however the immersion just kicks in at full draw ~2-3kw which is way more than the excess power (~300-700w) its not much power but was led to believe it will just heat water slower than at full wack. Obviously this aint what i wanted as i wanted the energy of the pv to be the source of power to heat the tank.
Do some elements only draw their max power or could it be faulty?
Also the pvmate is wired directly to the element which has its own built in stat, which i was told to turn to higher than the existing setting as that may have caused 'water tank hot' messages on the pv mate unit, but as u have said above, there is no way it can know this unless its aware that theres someway it knows just by having the stat 'block' it, but im unsure this is really how it would do that.
Hi
Currently, during the winter, I don't use the pvmate at all. I have a timer that comes on for a period of time at night to heat the hot water. Then when winter ends, I'll plug it back into the pvmate and use the sun to heat the water. I wanted 2 elements really, that way I get the best of both worlds, but to do that I'd need a new tank and that's just silly. There appears to be no such thing as a twin element heater, apart from commercial offerings and it's simply too hard to do myself safely. So I've gone for the simplest route, change it manually twice a year. For the summer, I have it set to come on for anything over 800W, that way, the house and the house battery still get power, for the winter, it's off and I plug the element into a smart socket that switches it on at full 3kW. I may consider dropping down to a 2kW as I feel 3kW is a bit too high.
Sorry, but unless you buy a smarter system, this is what you are stuck with. there are ways of doing this better, but spending £100s more is not best for me.
Hi
Ok thanks for the input, how exactly do you set it to come on when its >800w, i dont think my pvmate has any setup details like that.. best regs
Oh sorry, I ended up buying another one that worked. The PVmate I originally bought was rubbish and simply let me know. So I bought one that connects direct rather than wireless signal. I was mixing my threads. :)
