arebee70
- Jan 9, 2023
- 2
- 0
- 31
- United Kingdom
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Hey styler, how did you get on after the thread died down, i found this by searching for pvmate-immersion related problem and have basically a similar problem where the pvmate sensor collar is fitted correctly and is triggering the pvmate immersion controller to start up when excess pv elec power goes to the grid, however the immersion just kicks in at full draw ~2-3kw which is way more than the excess power (~300-700w) its not much power but was led to believe it will just heat water slower than at full wack. Obviously this aint what i wanted as i wanted the energy of the pv to be the source of power to heat the tank.
Do some elements only draw their max power or could it be faulty?
Also the pvmate is wired directly to the element which has its own built in stat, which i was told to turn to higher than the existing setting as that may have caused 'water tank hot' messages on the pv mate unit, but as u have said above, there is no way it can know this unless its aware that theres someway it knows just by having the stat 'block' it, but im unsure this is really how it would do that.
