OK, some good advice on here to help me try a few things. So I turned off and had a look and pressed any button that looked like it could reset, nothing obvious. Then I notice the second thermostat, I think that is an override one, I adjusted the temp on that, but that should not make the difference as it worked before.
Then I flipped the clamp to trick it into daytime and it fired up! odd. First sent 85w then went higher...obviously because it was drawing power itself and increased to suite etc. Went up to 2.7kw. So I've flipped it back and will check tomorrow night to see if it has drawn anything from daytime.
