Discuss PVC Conduit Question in the UK Electrical Forum area at ElectriciansForums.net
RDB85
Trainee
I’m looking to buy some PVC Conduit for some security lights rather than clip the cable. We don’t use it in work. But I know I need 20mm conduit but would I be okay using 20mm inspection elbows? I assume they just fit inside?
No the tube fits inside the fittings and Don't forget to use the adhesive!!!!!
I’ve been given a length of 20mm PVC so I would need 25mm fittings.
No, 20mm fittings are designed, for 20mm conduit, you may need a bending spring as well as a tube cutter if you are doing a lot of tube work, although a Junior Hacksaw will do the job just as well, although a cutter makes a better job of cutting use Heavy duty tube it's easier to bend and work with. In my considerable experience. Light duty tube tends to kink when bending,
I would avoid manufactured bends and elbows they look terrible in any instance. Get a bending spring and use sets wherever possible and use BESA boxes as opposed to the fittings you suggest.
The inspection bends do not allow a cable draw tape to push around the bend without taking off the face plate or perseverance, better to use a slow bend or as suggested above a bending spring to get a slow change of direction.
Yep and saddles, box lids and screws and if outside some waterproof gaskets,
Only thing I might add is that 'waterproof' gaskets don't waterproof. By all means fit them but when designing an external system always assume water will get in. Allow for drainage, by for example, fitting a terminal box at the lowest point with a small drainage hole. Do not enter lights and accessories from the top, come in from below or the side, and keep all joints out of conduit boxes.
Manufactured inspection elbows look terrible and amateur/DIY. Get a bending spring and make required bends. It's also cheaper in the long run.
Never used a bending spring. I will order one and do all my straight cuts and see if I have any scrap left to practice with.
New posts
Reply to PVC Conduit Question in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Hello, Im really new to the world of conduit. I have some 25mm pvc conduit and cant for the life of me seem to fit back boxes with 25mm...
5K
Hi Guys Any one know the current carrying capacity of a 4mm 3 core single phase sy cable ran in a 20mm pvc conduit? Not sure of the right table...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
