With all this new info, so quickly, I wouldn't be surprised if he's GLUED up.Hope the poster is all clued up now good luck Matey.
Hope he aint stuck up, hope it works out for him, despite the banter.With all this new info, so quickly, I wouldn't be surprised if he's GLUED up.![]()
Manufactured inspection elbows look terrible and amateur/DIY. Get a bending spring and make required bends. It's also cheaper in the long run.Okay that’s what I’ve got. 20mm fixings, inspection bends and elbows. Looks like I will need some adhesive.
Only thing I might add is that 'waterproof' gaskets don't waterproof. By all means fit them but when designing an external system always assume water will get in. Allow for drainage, by for example, fitting a terminal box at the lowest point with a small drainage hole. Do not enter lights and accessories from the top, come in from below or the side, and keep all joints out of conduit boxes.Yep and saddles, box lids and screws and if outside some waterproof gaskets,
Never used a bending spring. I will order one and do all my straight cuts and see if I have any scrap left to practice with.
Me, I use a back entry on an end box and shoot off from there, better than an Inspection elbow I reckon, but each to their own I guess.what's wrong with inspection elbows? how else do you come through a wall and then 90 degrees (up/down/left/right)? do youm bent the tube and have it sticking 4" off the wall?
Not to put too fine a point on it, but they are truly awful.I would avoid manufactured bends and elbows they look terrible in any instance.
???? The pipe goes INSIDE the port on the fittings, it should stay there on its own, no need to cut anything, it just pushes in.
