RDB85
Trainee
I’m looking to buy some PVC Conduit for some security lights rather than clip the cable. We don’t use it in work. But I know I need 20mm conduit but would I be okay using 20mm inspection elbows? I assume they just fit inside?
I did use plumbers pipe once myself. For running CCTV along the front of my own house. I’ve got a bay window, and the plumbers pipe come with 45’ bends.
Overflow elbow used on white and black conduit...
the other end went to:
Please please please can we see a pic of that...
If you must......
Yes, I just left the ends open. Bad of me.
Built it up with the cable inside already, and it’s glued. The bends have a corner inside them, rather than a sweeping smooth run.
Only for ELV and cctv signal.
Going off at a tangent ...
Interestingly I've noticed that for galv conduit, you can get solid (non-inspection) bends, elbows, and tees. I'm thinking that threading stuff through conduit with non-inspection tees could be "interesting" :confused:
Solid bends and elbows have always been about a tee seems odd but have just seem them online. How would you wire a tee and guarantee it went the correct way.
I guess you'd need a bit of a set on the end of your tape - and keep the tape the right way round. I'd be more concerned about getting past the inevitable edges to get into the next tube.
use string and a henry. suck from the place you want it to come out, with any othe outlets plugged or taped over,.
RDB85
Trainee
Liverpool
Trainee Electrician
PVC Conduit Question
RDB85,
timhoward,
