Discuss Question about discharging nimh cells in parallel in the DIY Electrical Advice area at ElectriciansForums.net
GTR450
Hi,
I have question about paralallel discharging NiMH modules. I have 40 modules and one modul consist of 6 x 1.2V cell = So nominal capacity is 7.2V.
These modules are in car connected in series. But I replaced 15 bad cells and now I need balance them. In one thread I have got good advices but in the end I need one more help. After discharging and charging process every module without load have 8.75V and I need to discharge them to 8.4V because car Computer shows error then. Can I do it in parallel? I have connected all the positives together and all the negatives together like in the pictures. So in parallel they are together like 8.75V but what is with capacity? Every module has 5000mAh capacity so its like 5000 x 40 ? Am I wrong? Can I discharge them to put some bulb betweeen all the + and all the - ??? Thank u.
Sorry for more replies i cant upload to main message :/
Reply to Question about discharging nimh cells in parallel in the DIY Electrical Advice area at ElectriciansForums.net
Hello I have question about connect to 40 nimh cells with 8.4 - 8.7 Volts parallel. I need balance whole battery pack for hybrid car. Is it safe...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
I am a retired Electrician and started looking at Solar Power, (Black Magic to me), after much reading of "How To", I decided to build myself a...
Hello everyone. I bought some property in northern Michigan. It has underground electric with a transformer already on the property. I would like...
