Discuss Question about outside Lights in the Industrial Electricians' Talk area at ElectriciansForums.net
R
RacerA3
Hi Guys/Girls
Heres the problem I currently have and Outdoor RCD double socket outlet on the side of the house. I have garden lighting transformer and control unit (Low Voltage) plugged into this. The thing is however it requires me to go outside to turn the lights on. Id like to have a switch to turn the lights on from inside the kitchen. I was justing wondering how you would this ?
Many Thanks
Id considered that but the room has just had new wall paper put up and im not 100% where the socket is fed from, i think it spurs off the kitchen ring. Also ive only got room for a single gang back box.
Many thanks for the reply Paul.
Could i take power to a switched spur. Via a Lead plugged into the RCD socket? Or if i fitted a RCBO take power (spur) from the outside socket ?
Also the consumer Unit is pre-split load boards
Why not just pull the cable back thouch the hole ,fit a switched spur and re feed the outside socket ,sounds to simple,maybee im missing something
good luck
find which socket its fed from, if its spured off there will be three cables in the socket, then either put a spur next to the socket or change the socket for a spur if its only a single. other option are change a double box to a dual box so you can have a spur and a single socket without much work involved
Reply to Question about outside Lights in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
