Good morning all,
Probably quite a simple question for all of those who use thermostats/temperature sensors regularly.
I'm in need of a thermostat which has the ability to close it's contacts once the temperature in the room has reached a degree which is deemed too high.
Do most thermostats have the capability to do this rather than just pulling in once the temperature is too low?
Looking for a 230V stat which would do the job if anyone can point me in the right direction! (Will be used to pull in 3 x contactor coils, each with a 5A load max)
Thanks!
Hi - possibly you are after a single pole double throw switch, but often cheap domestic ones are only single throw. Check out Honeywell T6360B, as it should work.
Newcastle Upon Tyne
United Kingdom
Quick Thermostat Query
IAmSparkytus!,
Wilko,
