Discuss Quiet contactors needed for some 20KW fan heaters in the Commercial Electrical Advice area at ElectriciansForums.net
UKMeterman
Hi,
I am looking for some quiet contactors to control a pair of 3 phase 20KW fan heaters in an art gallery. Are there any favourite suppliers?
Don't fall for hagers 'silent contactors'. Seen someone fit them and they are exactly the same as normal one. Turns out the silent is the 'hum' that most new contactors don't produce anyway.
Why would you need to label the local isolation.
Because everything has to be decorated with stickers these days to make it look pretty!
Even the NICEIC womble who came to visit last year wanted me to start putting 'danger 400V' stickers at regular intervals on the lid of trunking in case someone didn't realise there were cables in there 😂
Guilty as charged, I have put L1, L2 & L3 stickers on 240volt socket outlets where distributing single phase from a three phase board especially when you only have a 12Kv supply and the tumble dryer and washing machine are side by side.
I would be looking at something like this.
bear in mind that when solid state contactors fail, they normally fail in the “closed” state.
it may be necessary to back it up with a normal contactor on an over temperature stat to prevent the element from overheating if the solid state fails.
Maybe also worth mentioning that solid state devices shouldn't be used for isolation.
Nowt wrong with that for circuit tracing.....should be 1L1, 1L2, 1L3 though, for the circuit involved.
This was in a domestic environment and 1L1 etc would not mean anything to a French electrician or domestic user, the 1 at the front is superfluous with only one three phase supply into the property.
But this situation was and I was commenting on the sensible need for labelling in some situations if this was a three phase supply being distributed as single phase in a UK property.
Bleedin' mind readers now, are we?
We talk about 3 phase supplies here and usually it infers a commercial or industrial situation.
Maybe, I should have read a bit more into it, with such a small supply, although the comment was about general UK installations rather than a frog house. 🙂
Reply to Quiet contactors needed for some 20KW fan heaters in the Commercial Electrical Advice area at ElectriciansForums.net
When working in a control panel. If I needed to replace a 3 phase contactor do I need to carry out a 10point check to prove dead on just the mains...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Hi Guys, sorry if posting in the wrong section. I am due to start 2391-52 course soon, and there seems to be from what I have found out, a 3 phase...
Hi, These electric heaters have been installed and are generally operated via the HeatApp on a mobile phone. However the pairing has been lost and...
