Discuss Quinetic switch advice in the UK Electrical Forum area at ElectriciansForums.net
Hi All,
looking for some advice from anyone that knows about the Quinetic wireless switch.
light currently on a traditional 2 way switch, looking to make it 2 way, but the second switch will be bottom stairs. Cable were run into artic but never used, havent a clue why.
house is an old with lathe and plaster, so don’t want to upset it too much as recently decorated.
question is do Both light switches need to be quinetic wireless or can the receiver be connected, whilst still using the original traditional switch.
electrician not really keen due to running cable. But will do do if can do it with one wireless, he don’t really know bout them hence why I am researching.
appreciate any help or advice.
The receiver requires a neutral. It can be configured as you say with a bit of adroit wiring, but why would you do that it defeats the purpose of the switch? Do you have a neutral at the switch?
Lost me a bit mate, are you asking if one switch can be traditional cable fed and one can be wireless??
Yes thanks exactly what I am asking
[automerge]1593553026[/automerge]
I believe the sparky said there was.
Reply to Quinetic switch advice in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hi All, I am looking to install a Quinetic double gang in line receiver switch (QURS2W) in my hallway on the ground floor to control the lights...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
Hi all, I am upgrading my traditional 2 gang light switch in the kitchen to a smart 2 gang dimmer switch. When I wired up the switch the switch...
