Discuss Quinetic wireless kit (can it be used with photocell) in the UK Electrical Forum area at ElectriciansForums.net
supply L & N to the receiver from the photocell. so you have feed to photocell, then after dark feed to receiver, only then will the switch activate the light.
I would do it the other way round and provide the receiver with the permanent power. Depending on which receiver you use it may require permanent power (the WiFi enabled units for example). I'm not sure how long the receivers retain any data without power for long periods.
That ok? Was having a moment
probably a better way. trial and error maybe useful.
[automerge]1568187149[/automerge]
looks like the receiver will override the ptotocell done like that. you need to feed Lout from receiver to photocell, then to lights.your pic shows S/L from receiver directto lights.
First pic is if I want to override the photocell with switch
Second pic is if I want to just control the photocell so when it’s dark lights come on and go off when light or when receiver switch is off
I think the second version would be ok. The receiver controls everything downline from it. Never used Quinetic with a photocell though, but i think it would work...basically, power up the receiver with the switch, and then the photocell acts as a secondary switch. Coincidentally, I was doing a demo with my Quinetic demo kit this morning. It has been in its box for at least 6 months without any power to it, and the switch did not need to be paired again, it just worked...out of the box, so to speak.
Reply to Quinetic wireless kit (can it be used with photocell) in the UK Electrical Forum area at ElectriciansForums.net
I am installing some driveway lights. The customer wants to be able to switch them on from t he house, but also have a PIR at the driveway...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
Well this is a first.... a fault with Quinetic gear. Lighting circuit running up to loft, a box with 3 Quinetic dual receivers, and then...
4K
Hi folks, I have been out to quote for a soffit lighting job. I have done jobs like this many times but usually only installing lights in the top...
