Unless they have changed the design, the Wylex ones are not completely off when open. I remember IR testing the busbar of my own board and found they have a hundred or kOhm still. However, I don't know if that is the main powering sources or not (i.e. if switching on changes it).
The Harger RCCB I have tried seem to IR open on both sides, so I guess they use a capacitive divider. That should be more energy-efficient than just a resistive divider but I don't have a spare Wylex RCBO to test those theories out.
I've only skim read this thread, but it looks as though this video might be relevant:
(they also measure some RCBOs, neons, and USB sockets from memory)
I always try to fit MCB/RCBO/fuses as low a value as possible, to give added protection in fault conditions on connected appliances.
But at #49 you say "Which brings me to the point of using the highest mcb rating you can to reduce the bi-metal strip bending consuming energy and getting warm"
In Other posts, you complain about loss, but you say you use the smallest cable you can get away with.
Small/Large Thick/thin which is it because you seem very confused.
Given chance he would argue with himself and I'm sure he did in a thread a little while ago
That Efixx video was useful, even at double the originally measured cost it seems the RCBO is only using around £1/year so less than depreciation if you assume a 10 year period for them and as-new cost of around £20 (and given the cost of AFDD well below their depreciation cost).
What was also said at the end of the video was about much higher usage on "stand by" like the speaker with Alexa, managing to simultaneously steal your money and privacy!
From memory by VM router/modem takes about 6W so is more like £20 per year and way more than my CU.
You have poor comprehension. Read what I wrote again. It was clear enough.
Excellent vid. Even Big Clive commented in comments section. They pointed to another vid at Lewden testing AFDDs. AFDDs combine four fault protectors in one unit. The longevity of AFDDs maybe in question they have complex electric boards inside, unles you pay a fortune for the top quality makes. But you can get around the AFDD regs by installing a ring final circuits supplying sockets, with 4mm cable and a 40A RCBO/MCB.
No you can't, for installations where AFDDs are required they are to be installed for all circuits supplying socket outlets rated at 32A or less. It is the rating of the socket outlet which is 32A or less, not the rating of the circuit.
Additionally, a ring final circuit is defined in t'regs as having a 30 or 32 amp protective device:
433.1.204
Accessories to BS1363 may be supplied through a ring final circuit, with or without unfused spurs protected by a 30A or 32A protective device complying with BS88 / BS3036/ BS EN 60898 / BS EN 61009 etc.
If we went back to 14th edition things were a bit different then.
52p per ann. to run a neon light, which will be approaching a £1 now energy has risen. Have three and £3 per ann. With all the rest of the standing losses in the hosue and in the CU you can pay for a night out. Add all this up over a whole nation and maybe a fossil fuel power station feeds it.
52p per ann. to run a neon light, which will be approaching a £1 now energy has risen. Have three and £3 per ann. With all the rest of the standing losses in the house and in the CU you can pay for a night out.
Either you have a massive CU full of circuits, or you live somewhere incredibly cheap!
Even up here in Dundee, which is hardly known for affluence, I won't get much of a night out on the £5 of my flat's always-on RCBOs.
John-SJW,
westward10,
