C
charlie76
I need to work on a board with no RCD protection. Rewiring kitchen lighting and adding downlights. Is it acceptable to install a 30mA RCD spur unit at the consumer unit, feed the spur direct from the MCB, fuse the load side at 13A (Leaving the 5A MCB protecting the circuit) and use this for the RCD protection of the lighting circuit? Therefore the whole of the circuit is then protected.
Personally I would favour a board swap but the clients wallet is not allowing.
