Discuss RCD / GFCI testing from across the pond in the UK Electrical Forum area at ElectriciansForums.net
I have always disliked those terminals, I still can't believe they don't sleeve anything. Don't get me started on IP ratings or the phrase HOT WIRE. The moon landing was definatley staged
Reply to RCD / GFCI testing from across the pond in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
GFCI green light is lit when not under power draw. The bidet seat functioning causes light to pulse yellow (and creates a pulsing and knocking...
I have a fairly recently installed consumer unit with an RCD, between it and the garden there is another, much older (25yrs?) RCB (big Wylex...
Weekend sparker here, I have a sqd 2 pole 50amp GFCI breaker it was mounted out side in a service box, have not had a problem till now 3yrs old...
