called to a static caravan today to do some fault finding, first port of call was to check outside supply box and found that rcd appeared to be wired input/output wrong way round. then got thinking does it really matter?
Do you think it does?
Do you also think it matters if you reverse the polarity on an RCD?
I always thought it did matter and always wired them input at top output at bottom (checking manufacturers instructions also), but then started looking at a few nearby caravans and their supply boxes only to find they all wired upside down to way I would have done
It's not right but, I think the rcd would work but something's telling me the test button wouldn't
