J.C.E
Is there such thing as a three phase RCBO??!
Needing to install a three phase circuit for a 8kw three phase heater- connection by a 20a comando
I want to use the metal trunking I will be installing for various 13a sockets- so the circuit doesn't need the rcd protection- but i beleive the 20a comando will..
It will be a new hager TPN dis board
so hows best to get fault and additional protection in TP setup?
This any good?
MK K13435 3phase 415V 5pin with 40A RCD, Commando 32A Socket Rated | eBay - https://www.ebay.co.uk/itm/MK-K13435-3phase-415V-5pin-with-40A-RCD-Commando-32A-Socket-Rated/323637491756?hash=item4b5a4c382c:g:4yEAAOSwQwRb6CsX
Could you not fit a 20 amp isolator instead and hard wire the heater in , then you would not need the rcd ? Failing that you could get your customer to do a risk assessment and omit the rcd :)
J.C.E
Earth
RCD protection in a warehouse
J.C.E,
Flanders,
