Discuss RCD protection in a warehouse in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
Is there such thing as a three phase RCBO??!
Needing to install a three phase circuit for a 8kw three phase heater- connection by a 20a comando
I want to use the metal trunking I will be installing for various 13a sockets- so the circuit doesn't need the rcd protection- but i beleive the 20a comando will..
It will be a new hager TPN dis board
so hows best to get fault and additional protection in TP setup?
I did similar a while ago and used a 3 phase MCB at the DB then an enclosure with a 3 phase RCD and 32a socket 'all in one' at the other end but mine was in SWA .
Just Googled it...obvious really.
If it helps another divy the same current has to return through another phase if no N.
Could you not fit a 20 amp isolator instead and hard wire the heater in , then you would not need the rcd ? Failing that you could get your customer to do a risk assessment and omit the rcd :)
Reply to RCD protection in a warehouse in the UK Electrical Forum area at ElectriciansForums.net
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
Hi there , Currently doing a college project where i need to select protective devices for the contract. I'm now at the point of selecting SPDs...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
