Just a suggestion how about the diy section not requiring a log in to prevent diyers searching the rest of the forum
most people won't bother with registering if they don't need to
or alternatively require proof that you are qualified and/or work in the industry to view the main forum
that will ensure that diy questions remain in the diy section
I honestly think people should be capable to do the very basic electrical work on their property without the expense of "calling an electrician". By that I mean anyone with half a brain should be able to change a socket or a lightswitch. Same as bleeding a radiator or putting up a shelf from Ikea. (Some of the instructions for shelves and cabinets require Phd's!)
In my experience, I find it's the older generation guys who have trades in construction are the one's who are most likely to do DIY electrical, plumbing work. For the most part it's done quite well (conduit used etc) but they'll not know to extend rings and as a result you have 5 or 6 sockets spurred off one and off the original 30/32 amp breaker.
So I feel the advice given out shouldn't really be much more than things like:
By a socket tester and/or light pen.
Test to show cirtuit is live.
Switch circuit or even whole CU off.
Ensure light switch/ socket is dead.
Check this again.
Swap socket/switch or even light if it's not a 3 plate which may be too complicated.
Pull cables to ensure tightness.
Switch back on.
Test to see if working.
Job's a good'un and you've saved 40-50 quid.
So what testing does a DIY'er do after changing a socket? Do they carry out an EFLI to ensure that the OCPD will operate? Do they test RFC end to end continuity to make sure that one side hasn't broken off or come out as they've crammed the socket back against the wall? Of course they don't, but I do, as an electrician.
The job might "work", but it doesn't mean that it's a "good'un"...
If somebody can't change a socket they shouldn't be left in charge of turning gas hobs on or off!
there is a bit of difference between turning a gas hob on/off and fitting a new gas hob, though. :toilet:
There certainly is, you need to be GSR to change a hob.
It terms of danger though I'd stick it like this.
Easy
Change a plug
Change a socket
Turn on a gas hob and safely turn if off again
Change a gas hob
Hard
haha (I'm messing by the way)
Changing a plug is easy IMO
However by the amount that I have seen that are utter **** I have to rethink....
I see - we are lead to believe there is no sponsorship involved, so if no cash changed hands presumably this must be part of some elaborate under the counter, behind closed doors deal struck between Dan and the CEOs of the multinational DIY chains in a 'you scratch my back and I'll scratch yours' fashion, within the secrecy of Dan's local Masonic lodge.
Quite a coincidence that this should all happen so soon after the Bilderberg conference, which I am sure Dan attended.
Either that or it's to open up new avenues to make the forum busier.
Maybe we could have a new section on auto electrics, with a subsection for general car repair?
And a section on DIY plumbing so we don't have to go over to that plumbing forum.
I believe this has been hashed out for the regulars benefit as there was that huge thread about everyone jumping ship and in that thread they suggested a diy area. So that is what was done. And now your accusing them of alterior motives. I really do feel for the admin. Cant do right for doing wrong.
On the sponsorship note....what does it matter if they get sponsorship money from this site??? They have made it in their own time, have to pay for god knows what like domain names etc and we all get to use it for free....how about they just charge the moaners and then there would be no need for sponsorship
I realise that you and the admin are going to be "for" anything which brings in more visits, but it feels more and more like whenever someone says anything "not positive" about DIY electrics then they're seen as simply negative and causing trouble.
The fact is, there are many electrical jobs which should not be carried out by anyone other than a qualified (often part P registered) electrician, yet you guys are making what we say sound more like scaremongering!
As for the above comment...In my opinion, only competent persons should be changing a socket, and carrying out some form of testing afterwards. It's not at all like "turning a gas hob on or off!"
I appreciate it's 'all electrics' and having a load of professional electricians in one place sounds like the ideal place for a DIYer to ask for advice, certainly a great way for a website to attract hits, but at the same time if someone is having a go them self they're not employing an electrician to do it.
A professional telling a potential customer how to do the job for free would be denying them self business, kind of like a forum advertising a rival forum.
I know lots of members have been kept busy sorting out DIY installations and quite a few have been approached to come and do the job by DIY'ers who've posted threads when they've been informed about the pitfalls and complexities of the job they're trying to do.
The thing with DIY'ers is they're each at very different skills and experience levels. It's a matter of establishing where their safe limit lies and helping them to recognise this as well. I'm all for assisting them to achieve something safely if they're capable but it's a thin line between that and encouraging them to overstep the mark and their skill set where they'll be a hazard to themselves and others.
Helppppp!!!
I need to change a faulty bulb.
I've just been out to aquire some four step ladders.
Can someone give me some advice on how to use them.
