Discuss re wire ?? in the Australia area at ElectriciansForums.net
it does not have to have a RCD board. but if replacing the existing board, then you need to fit a dual RCD, or RCBO board to comply with current regs. as said previously, visual inspection, lift off accessories, make sure cpc's connected. PIR on whole install. then as long as cable is pvc, not rubber, and tests confirm that the circuits are healthy, you can go ahead and just replace the fuse board and any dodgy fittings. upgrade main earthing and bonding as necessary.. then a EIC for the work done.
If he's just going to sell it on why bother even testing it? Just change the old accessories and fittings for new ones, cover the old CU with a piece of ply and mount a new CU on that. stick on a few stickers and date the next inspection for 2020. It's then a new installation. Job done. Seen it plenty of times.
you following me round, LOL.
great idea !!!!
Reply to re wire ?? in the Australia area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hello, my house was built in the 1950s and every time I look behind a wall plate the wiring isn’t how it’s shown in any DIY book I’ve read. I’m...
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
