HappyHippyDad
Supporter
My customer wants to have a new out building, with a 40A supply. Sockets, lights, 1 x 2000w heater.
The house is huge, many bedrooms, Hob, cooker, Hot tub, an existing outbuilding, Immersion, sockets x 3 circuits, Garage sockets, 6 x lighting circuits and 2 further circuits for separate fish tanks.
It is a single phase supply. I don't know waht size fuse, but even with a 100A fuse my max demand is going to be way over 100A.
I realise that a house never really gets up to it full demand and reality the main fuse never blows, but this is quite alot! I usually wouldn't worry too much, but again this is alot.
What do you guys do in these situations? What are my options?
Can you clamp the tails and see how much is actually drawn at any one time?
Remember, houses in the past would run some 100W lamps in the house, 500W halogen outside… electric shower, cooker, a number of storage heaters, all quite happily on a 100A fuse.
Look at the appliances, rather than number of circuits.
How many kW is the hot tub?
My brother in law has a big house with single phase 100A cut out. Loads include:
2 built in electric ovens
4 or 5 ring induction hob
2 dishwashers
1 washing machine
1 tumble dryer
7kW EV charger
7kW hot tub
LED lighting
2 air con systems
Oil central heating and water heating.
Never had an overload problem and he entertains a lot.
This might help :
Garo Priority Shower Board 6 Amp IP40 1 Row - https://www.meteorelectrical.com/distribution-control/consumer-units-accessories-1/garo-priority-shower-board-choose-priority.html
Note third para of product information.
I love some of the "poor translations" in that 🤣
That was going to be my suggestion as well - not that specific device, but generically a priority relay to drop some large load(s) should demand actually get too high.
A/C would be a good candidate (needs to be done by signalling to turn off, not just cut the power*), I believe some EV chargers can manage load themselves by monitoring total load on the meter tails.
* Some A/C systems don't like having the power cut on them while operating. Far better to let them do a proper shutdown, which depending on the system may include shutting valves before stopping the compressor to ensure the refrigerant is kept in the condenser coil.
I have a big advantage, solar panels, battery and inverter also means I have a display showing how much I have used. But even the Smart meter gives one a clue as to what is actually used. If I look at my house, two kitchens to start with, the load could be massive, but the 60 amp fuse has never ruptured, and I can see on the solar software never gets anywhere near that point, the 00:30 to 05:30 is my highest load, with tumble drier, dishwasher, washing machine, and the battery being recharged, but not actually ever hit the 60 amps mark.
