- Reaction score
- 3,068
The breakers don't sit straight after being tightened, they generally have a cheap feel to them, the brass screws on the earth and neutral bars are as soft as butter, it came pre-wired wrong with the neutral Coming out the bottom of the live terminal on the main switch (split board) if you tighten an mcb too much it splits at the top, the last could probably be saved by using a torque screwdriver though. I get wylex generally but the odd contactum alsoWhat did you find so bad? What do you usually fit
