Discuss Recessed MK boards .... in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Ok - being very lazy and could do with some input from the collective!
Viewed a refurb the other day and the existing CU is one of these:
So my question is - (I'm not a MK fan) is there an current product that would be an almost direct refit?
MK make skeleton boards to fit mantel still as do other makes.
Google "Mk Skeleton"
They were specific I think but they do do other recessed boards also. Do you have dimensions?
Murdoch don't like MK, TJ saw some Siemens ones at ELEX on Friday, give them a pattern of any decorations and they will offer a cover to the same pattern or color for a small price I would guess.
I knew they are still available - just hoping somebody would know if the current ones would be a direct replacement?
I would say probably not. All there stuff will be based on the current A3 layout. I had an old plastic stacked one I replaced. The metal equivalent had slightly different dimensions.
If your client has got a few bob, when not convince them about the Hager 50. You can have them painted any colour or bespoke artwork. They even have it sprayed that camel ---- green colour :D
Sorry duff info should say Hagar not Siemens
Why does it have to be MK?
It doesn't, but you will need to be sure that the new OCPDs or RCBOs meet the requirements of BS EN 61439-3, or even a product recall, failure to do so could result in a F1 or even a C1 or C2 on any future EICRs
It’s in the hall, so a surface unit won’t really be a suitable replacement
I’ve sent the photo to MK now so I’ll let you know what they say ..... their website is carp
Let the Forum know Murdoch, it will be interesting.
I am referring to installing a new recessed consumer unit eg like the Hager one we were looking at Elex.
Well.......That unit looks pretty grubby!! What's the rest of the house like? That will be one of those jobs where you bring your own flask of tea and say "No, I'm alright for a drink thanks" lol
Maad ---..... You'd be tellin' 'em to get a power shower for cleaning the new one.
Purchased and fitted my first mk board yesterday, never used one before and will never ever use one again such poor quality I expected better from mk of all people
The only bad thing about them is the mcbs go wonkey if youre too limp wristed to hold them straight as you torque the bus bar terminals correctly. Easily solved by not being limp wristed;) granted its probably the only brand that does it, but easily remedied and theyre soooo cheap..
What did you find so bad? What do you usually fit
The breakers don't sit straight after being tightened, they generally have a cheap feel to them, the brass screws on the earth and neutral bars are as soft as butter, it came pre-wired wrong with the neutral Coming out the bottom of the live terminal on the main switch (split board) if you tighten an mcb too much it splits at the top, the last could probably be saved by using a torque screwdriver though. I get wylex generally but the odd contactum also
and the response from MK reads as follows:
"Thank you for your email.
Unfortunately both the flush board and the RCBO`s for this board were made obsolete many years ago (1991) and have not been superseded.
We no longer manufacture flush consumer units.
Thanks"
So there we have it...............
I agree that they’re not the best but for the money I’d still stick one in a budget job. My go to dual RCBO/high integrity is Hager. Full RCBO in a domestic job I’ll normally shove in a lewden board as the RCBO’s are half the price of Hager, Wylex etc.
Rightly or wrongly id be re populating with new mk rcbos on that one, shoot me down if you wish, that walls gonna get destroyed trying to get that armoured gland fudged into another one
Absolutely agree. It's just a din rail enclosure. Put new Sentry Main Switch, an MCB for bell tx and RCBO's for the final circuits and then it's still all MK. I would really argue that changing that board is totally unnecessary when it can be upgraded so easily.
Great idea .............. sounds like a plan to me ..... but is there enough height in there for MK RCBO's?
Reply to Recessed MK boards .... in the UK Electrical Forum area at ElectriciansForums.net
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
Hey guys, Im starting to put my company out there more. And this is all a new journey for me being an apprentice and now being qualified/2391-52...
Hi guys. It would be really useful to run this past you and get a consensus/input from you for what would be a realistic amount to charge for an...
