Hi All,
I will be having a full rewire done shortly and will fit an LED floodlight for the garage and driveway, and one for our garden. My budget is £35 per light (or thereabouts).
So far, 2 manufacturers have come up in my research: Timeguard (Timeguard LEDPRO10B 10 Watt Black Professional LED Floodlight - Edwardes - https://www.edwardes.co.uk/en/products/timeguard-ledpro10b-10-watt-black-professional-led-floodlight) and Deltech (10W Slim LED Flood Light 6250K with PIR - Black | QVS Direct - http://www.qvsdirect.com/10w-slim-led-flood-light-6250k-with-pir-black).
Both are 10watts (although I know this doesn't matter so much), and IP65. The timeguard is 5000 kelvin, and Deltech 6250 Kelvin. The Deltech has 800 lumens vs. Timeguards 650 minimum lumens.
Are both reliable manufacturers, and which is the 'best' (i.e. more likely to stand the test of time)
Will the lumens stated be sufficient as security lights?
Thanks!
how large an area do you want to illuminate. 10watts will give about 10 ft. range of light, tailing off towards the 10ft. i'd be looking at 30watts for an average garden, say 60 ft. long.
with LED you will not be replacing lamps every few months, and the running cost savings will eventually outweigh the extra initial cost.
also kind to polar bears.
Thanks guys.
10w should be sufficient for garage, but will consider 30w for garden.
Halogen lights are a lot cheaper, is the extra cost of the LED justified, or are halogens fine?
Halogens are rubbish............................ and as for LED's - if you have sensor lights animals will set them off.
As I previously suggested ............... ask the spark doing the rewire....
love the animal bit. foxes come across the garden usually around 1 - 2 a.m. sensor light means i can observe them.
Timeguard is a good make, whatever you do, do not buy LUXNA from yesss, I have had a lot of issues and have returned 19 of the pir floodlights this year alone on my account as they repeatedly fail, have also had the same problem with their led lamps, such poor quality.
For the cost, you couldn't go wrong, even if they fail take them back and get a refund or credit.
North Wales
Recommendations for LED Floodlight for garage and garden
Rocky786,
Reynard,
