E
elsparko
or, tell your customer to leave the property whilst you are working and get your chase on with an impacter and a chisel bit, make good before the return home
Discuss Recommendations for multi tool blade for brick/plaster in the UK Electrical Forum area at ElectriciansForums.net
Hit a screwdriver with a hammer?? you Philistine, blasphemy. I trust you mean a demolition screwdriver.for the box use 5.5 masonry bit or something near that size, mark out the line , grab a masonry chisel or a joiners flathead screwdriver and knock out the square, it should come off quite easy once youve drilled all the way round
get it quite often with the diamond corer, if the wall is too deep i have to chisel out the 4inch block to carry on, usually a few good hits with the hammer removes it, but if not, get the chisel in the gap and prize it till the 4inch block snaps off
yes, a joiners flathead, one that does not belong to youHit a screwdriver with a hammer?? you Philistine, blasphemy. I trust you mean a demolition screwdriver.
Oh good man bugger someone Else's kit up.yes, a joiners flathead, one that does not belong to you
Just got a delivery from Saxton, so ready to tackle a job tomorrow. I'm taking down a glass-brick partition wall, and don't just want to hit it with a hammer. I got diamond tiped blades for my multi-tool and hoping it will slice nicely between the bricks. I suppose it all depends on what the grout is...just grout, or cement...
I will report back.
Reply to Recommendations for multi tool blade for brick/plaster in the UK Electrical Forum area at ElectriciansForums.net
