Hi all,
Hope you are all well and all is good!
Can anyone recommend a nice looking garden light that can be surface mounted with side or bottom entry, e.g. can be retro fitted with surface mounted cabling?
Thanks in advance,
Martin
Not really as you would compromise the IP rating. These are outside on a garden wall.
You've got to have a hole somewhere.
Depending on the design of the light, one at the bottom might be the easiest way to avoid water ingress....
London
Recommendations for surface mounted garden lights
Gringoking88,
IAmSparkytus!,
