T
Ted Phillips
Hi
New here, so greetings to everyone. Fitted Labgear splitter in loft a few weeks ago to split cable from outside aerial. (One now goes to new tv in bedroom, other downstairs to main tv) Signal is ok (100% quality on all freeview channels, but signal level only about 40% on most)
Only talking about freeview signal, not Sky.
I know splitter can degrade signal, so wondered if I should fit on these amplifiers? I’ve seen the various videos and can fit on in loft adjacent to outside aerial. However, I don’t know if this would effectively replace the splitter or need to be used as well as? Ie are the amplifiers with multiple outputs effectively multiple amplified splitters etc? The other query was that most of these amplifiers plug in at the tv end. Wasn’t sure how that works when the cable is connected to two TVs?
Thanks for your time?
(Thought it would be tricky fitting amplifiers, then cable to splitter et)
