Discuss Relocated water service bonding... in the UK Electrical Forum area at ElectriciansForums.net
SSE
Come across something I've not seen before. Basically from what I can gather a mains water stop cock & sink has at some point been moved to a different location in a kitchen. What we have is main water pipe (copper or similar) entering building at old stop cock location & there is a 10mm earth clamped to it, the plumber has then used a white plastic pipe to supply the feed to the new stop cock & sink location but this joins to copper under kickboards so that everything you see under sink is copper. Outwith the sink once they go under kick boards it turns back to plastic, the hot pipe included. They also have a 10mm earth clamped underneath sink between hot & cold copper pipes. Surely this isn't the correct way of doing it?
What are we trying to achieve when we connect a bonding cable to a service ?
Why does the location of the sink have any bearing on the above?
Reply to Relocated water service bonding... in the UK Electrical Forum area at ElectriciansForums.net
Doing an EICR on a commercial install, there’s a copper pipe comes down a pipe chase with the stop cock fitted onto it, it’s then pvc pipes that...
Not sure on this one. Mains water is coming up from the ground in lead pipe in bathroom. 2 inches of copper pipe before the stop tap. All...
Hello, Carrying out remedial work on a commercial site and I've come across a metal out building that has a water supply to it. The water pipe...
Curious about supplementary bonding, I have these two 4mm Cables loose and not connected to anything in my parents house. I presume they are for...
Disclaimer: I'm not going to attempt this job myself, I want a professional to do this job properly since I consider it non-trivial and need it...
