M
markerlis
just purchased a westinghouse havana ceiling light/fan with remote control, when the electrician installed it the remote would not work properly, when you turn the wallswitch on the remote will carry out one command then stop working until you turn the wallswitch off and on again, when you select the dimmer the light continuously goes to dim-off bright. the supplier replaced the whole unit, the electrician installed the second unit but we have exactly the same problem. the electrician is completely baffled, any suggestions would be appreaciated, thanks
