Discuss Remote Control Fix for "Always Hot" Outdoor Lighting in the DIY Electrical Advice area at ElectriciansForums.net
xrabbi
Our electrician inexplicably wired outdoor floodlights attached to side of house over driveway as "always hot", no switch. We don't want them always on, nor timed and also not with motion sensors. We want to turn them on and off from a regular wall-mounted switch like normal lights. All the walls are now closed so can't really change the wiring at this point. Electrician suggests getting remote control bulbs or sockets for those fixtures. We found remote control sockets (Dewenwils) that come with switches that can be wall-mounted inside -- but the sockets themselves are not wet-rated and apparently present fire risk in high temperatures. Any recommendations for other products that will do what we want without having to rip up the new walls? Appreciated!
Are the outside lights supplied direct from the board, or part of another circuit?
Wherever the source is, can’t a remote receiver be placed there?
Reply to Remote Control Fix for "Always Hot" Outdoor Lighting in the DIY Electrical Advice area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
I'm considering using several of the remote WiFi switch sets to control a group of five different lights. The existing switches are all grouped...
Autumn is now here, it's that time of year where the clocks go back and lighting control moves forward. A time when UK customers with gardens want...
I'm moving a socket installed on a lighting circuit (installed by previous owner who was a professional electrician so I assume he knew what he...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
