Cool Javelin
Hi Electrical experts:
I am new here.
Can I remove the sheath from the SER, only inside the conduit, to make it easier to thread the wires through the conduit and go around corners through LB boxes?
I am installing a generator on the side of my house (some 75' away from the Automatic Transfer Switch) and am running both a 4-4-4-6 aluminum SER cable, and also a control cable inside conduit.
In the garage I have the SER and control cable simply exposed, then they go into a conduit then through the wall then along the outside of the house.
To make it easier to bend the wire through the LB boxes, is it OK to remove the sheath and treat the wires like THHN? I would not remove the sheath on the 6 conductor control cable.
I live in the US, Washington specifically.
Thanks, Mark.
I am new here.
Thanks, Mark.
, but I believe stripping the sheath from the cable violates code in several ways - including removing identification information (on the sheath), modifying the cable from its approved state, and removing what little moisture protection is provided by the sheath.
