Discuss Removing a corroded lug in the UK Electrical Forum area at ElectriciansForums.net
Hi,
Does anyone know of a way to remove a corroded lug holding the neutral wire to a neutral bar in a meter socket? It’s completely stuck and I'm afraid of breaking the neutral bar if too much force is used, cause then we will have to replace the entire meter socket (it seems like they don't sell any replacement neutral bars just for the meter socket). Live electrical wires from ComEd are coming in at the top of this meter socket. I am trying to remove the neutral cable for troubleshooting an open neutral problem
Only the usual - tighten before loosening, heat, penetrating oil, impact driver as last resort. Why do you need to remove the cable at this point... can't you test from the panel?
BTW welcome to the forum, which is UK based. We do not have meter sockets in the UK, and if we did, they would be security sealed against electricity theft and only the PoCo would have access. So very few of us on here will ever have seen a meter socket!
I'd probably go (a bit carefully) with a cordless impact driver after giving it a soaking in WD40 and if it strips I'd drill it out and rethread with a tap that's the next size up.
Hi,
You don’t have to use the lug in the meter base attach the #6 bare wire to the neutral bar in the panel neutral bar
You need to be careful, that’s one wire you don’t want to mess with unless you turn off all power. You could easily put 180vac on your single pole breakers. You can get in trouble cutting that tag to be able to pull that meter. Leave the lug alone the NEC states to terminate that wire to your neutral bar.
Hi,
Cut the offending lug off clean and remake the connection. ensuring all is clean put some of that gubins you US sparks use to reduce corrosion, all you Guys seen to slap it on everything.
[automerge]1572455071[/automerge]
That should read "Slap it on"
Reply to Removing a corroded lug in the UK Electrical Forum area at ElectriciansForums.net
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
This from a while ago but reading about everyone elses problems tonight made me remember this one. The original job was the lights in a recent...
