Discuss Removing a knockout in an older box in the UK Electrical Forum area at ElectriciansForums.net
pfps823
Hi,
DIYer here with I think a super simple question. I'm trying to remove a knockout in an electric box. Tried tapping from both sides with a hammer and screwdriver but no luck. Seems like an older box. Definitely looks more solid than what I see today for sale. Any ideas on how to remove? Photos attached from both sides.
Thanks much!
Peter
Hi,
Thanks much!
Peter
Don't think it's knock out Mate, more likely a screwed conduit entry point, see the screwdriver slot in the pic from the outside.
Looks like it's got a slot in the blank, try big flat screwdriver and unscrew it.
Like Pete says.
If not drill a couple of small holes side by side and hammer a flat screwdiver in and twist.
Hi,
Thanks much!
Peter
Peter there is nothing to knoc out if you look on the sides of the box you will see 1/2 screw seals just take a screw driver and screw one of them out so you can use that hole
Is this me you are talking to Mike?
Reply to Removing a knockout in an older box in the UK Electrical Forum area at ElectriciansForums.net
I have an older Crouse Hinds board with a 200A service. Due to recent rehab on the house, I found I have the need to install a sub panel. I...
Have a contractor trying to run a new electric line to a 'picture light' over the fireplace mantle. As you can see in the photos, the entire...
I collect old Electrical Fittings and I recently acquired this vintage Junction Box (photos attached). I've been trying to figure out how it would...
Hello, I am posting to ask what is the best way to remove some Virgin cables that are clipped to the side of my bungalow, and the associated...
5K
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
