Discuss Replace blank plate with socket in the UK Electrical Forum area at ElectriciansForums.net
diynot
Hi. Existing standard blank plate, which I would like to change to an electrical socket to feed a kettle or a toaster for example. The blank plate cable run looks like it feeds two separate electrical outlets. One is used for the ignition only on a gas cooker (via 13 amp plug) the other is used for a cooker extraction hood, again with a 13 amp plug. Is this something that can be done, or could it potentially overload the circuit (if that's the terminology to use)
Hi westward10.
Here are some attached pictures as asked for. Thanks.
So the cable from the bottom of the box goes to feed two sockets?
Hi, yes that's right, well I am assuming another feed is taken through the wall from the socket feeding the microwave to provide a socket for the cooker ignition. I was wanting to plug the cooker extract hood into a socket where the blank plate is, which is temporarily using another, completely separate socket (wago connectors in the plastic junction box you can see)
Without testing there is no way of confirming whether this can be done or what has been done is compliant. If it is a 30/32A ring final circuit which needs verifying then the spurred section should only support a single outlet, additional rcd protection is also required. The original circuit has undergone alterations and I would recommend you have it tested to confirm its integrity just from the pictures the back box is not earthed.
Hi. Ok, good advice, I was in two minds about this. Thank you again.
I definitely think it would be worth having it looked at by a professional. I would have thought that was installed between '70-77 (judging by the green sleeving, stranded cores and not being tined). Plenty of time for owners to make alterations.
All depending on what wiring/circuit are behind the blank plate
Yeah, sounds about right 70's. And there have been a lot of changes etc. I'm leaving it. Getting a pro to sort it.
Reply to Replace blank plate with socket in the UK Electrical Forum area at ElectriciansForums.net
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
