P
Phil
No mention of any safe isolation, no mention of a volt meter never mind an approved voltage indicator if you want its full title anywhere in the tool list,
Socket back box and faceplate
Cold chisel
Plaster filler
Hammer
Hammer drill and masonry bit (12-18mm)
Electrical screwdriver
Pliers
Wire strippers or craft knife
Gloves
Goggles
Pencil
Spirit level
oh and on the tip list it says to get it signed off by an electrician when you have finished;
finished what? having a cardiac on the floor because you did not check it was safe to work on
Cold chisel
Plaster filler
Hammer
Neon Screwdriver Electrical screwdriver
Pliers
Rubber Gloves Gloves
Goggles
Pencil
Spirit level
I can`t believe you didn`t mention the "Cold chisel"
To achieve this you would need the fridge set to 4.5 and place it in for 30 minutes previous to commencing the works
"Step 5
If you are working on a ring circuit, twist together the wires for each terminal (live, neutral and earth), push them into the terminals and screw tightly in place with an electrical screwdriver."
No don't twist them together! Also it says "if its a ring circuit". What if its a radial circuit and its not the end socket? How will a DIYer know?
As Phil says, no mention of testing for dead, locking off or removing the mcb so the wife doesn't turn it on Si she can watch tv whilst diyer has the cables in his hands! Accident waiting to happen.
"Step 5
If you are working on a ring circuit, twist together the wires for each terminal (live, neutral and earths along their entire lengths and shove it down one piece of green sleeving), push them into the terminals and screw tightly in place with an electrical screwdriver."
It's a joke, and perfectly legal under Part P!
And also tighten up with an electrical screwdriver! I wonder how many people will take a cordless to the terminals and shatter them?
"Get an electrician in if it doesn't work."
It should say "get an electrician in as it would only cost about £70 and it would be done right."
And next week children we will do a step be step c/u change so no need for those expensive tradesmen that have spent years learning how to do it correctly.
picked up on some install tips, mainly this one. lol
Wrap some masking tape around your drill bit so that you know exactly how deep to drill the hole for the new socket back box.
Replacing a Socket the 4 Homes way
Phil,
AP Electrical,
