Discuss Replacing PIR with switched live in the UK Electrical Forum area at ElectriciansForums.net
mike105
Hi. (I hope this is the correct forum - first timer looking for advice.)
I want to replace an existing security light with a new one. The existing light has a switched live, allowing it to be switched (from a 1-gang 1-way wall switch) either so that it is permanently on or so that the motion detector is enabled. (It's similar to this one: Byron Elro ES94 GLS / 23W ES 4-Panel Wall Lantern with PIR Motion Detector Black,100w: Amazon.co.uk: Lighting.)
Is it possible to wire a new light to act in the same way (i.e. so it can be switched on permanently, by-passing the PIR)? The ones I've seen in the local shops just have the normal live, neutral and earth fittings.
Thanks.
Some PIR fittings have a feature where they operate as a 'motion detector only' if they are switched on but if you toggle the switch the brief power interruption puts them in 'permanently on' mode.
Most lanterns are fairly basic and will not have an easy method of bypassing the PIR sensor, often floodlights (not LED floodlights) do have the additional terminal.
If you really want to be sure of having the manual on function then you could wire a stand alone PIR sensor that can have a manual override before a non PIR lantern.
Thanks, yes, but I was hoping that we could continue to use the switch in the same way.
Are these easily available?
Here is the original wiring.
What would the best way of wiring one like you refer to? Just terminate the SL/yellow wire, and use the N, L and E as normal?
These are standalone PIR sensors with a manual override connection available.
These are coach lanterns with PIR which I believe have a manual override connection.
One without the override connection would just terminate the yellow wire safely at the fitting, remembering that it can become live if the switch is operated.
Use LNE as usual.
Please could I double-check how I would wire the standalone PIR sensor using the original manual override (i.e. by means of the wall switch). Does this look OK / safe to you? The yellow wire is the existing switched live from the wall switch.
looks OK. the PIR will switch the light and so will the yellow from the switch ( manually)
Reply to Replacing PIR with switched live in the UK Electrical Forum area at ElectriciansForums.net
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
