S solo2771 Oct 3, 2009 #1 hi just wondered how high the resistance between phases should be on a 3 phase board?
X xraytek Oct 4, 2009 #2 Insulation resistance? >1M and tested at 500Vdc, but if the reading is <2M then investigation is required.
S solo2771 Oct 5, 2009 #3 the measurments we got were very low less than 100 ohms, on the board are mainly single phase but there is a 3 phase air con unit and a 3 phase supply to another dis board?
C cosine Oct 6, 2009 #5 yur testing through something make sure you have everything isolated regards cosine
