Discuss Resistance Level 2 - HELP NEEDED!! in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
J
james1985
hey,
I am currently completing City & Guilds level 2 and stumbled across the below questions and scratching my head...
1. Electric Fire element has a length of 10m, a cross section area of 0.5mm2 and resistance of 50 ohms - calculate resistivity of material used.
R = U x L (SorryI don't know how to use the correct symbol for resistivity)
......... A
Resistance is equal to resistivity x length divided by the area
Any material has a natural resistance.over longer distances the resistance gets higher
If the area is increased,the resistance gets lower,distance and area are proportional
From the information given and the values you can transpose the formulae to work out the resistivity
hey,
Have you not been taught how to calculate the resistivity of a material, it's quite a simple formula
......... A
Rho
Des, from using that formula - I could not locate the material used. Not matched the resistance level provided...
This is taking me back decades
If I were given the information I would look up what material most heating elements are made from (mostly nichrome) then find out its value of resistivity and go from there
Not going to tell you the answer James, google how to calculate the resistivity of a material? the answer is there.
No Rho= LxA/resistance, watch out for the csa part, you will need to find the sq root of 0.5
Ok so am incorrect in saying the answer is 2.5?
Think so yes, just thinking I used to be good at this sort of thing, age certainly take it's toll on the memory. Hang on til Dave gets back don't want to add to the confusion.
Its fairly difficult to write the formula and/or a worked example so here is one. Hope it helps. It is simple but you need a sci. calculator.
Reply to Resistance Level 2 - HELP NEEDED!! in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi Guys, I'm doing my Level 3 C&G design project and just have a few design related queries which i am so far struggling to find clarity on...
Hello everyone, I hope you are all keeping safe? I'm after a bit of advice. I carried out my level 1 and then Level 2 qualifications and passed...
Hello, After my post back in 2018, I decided to take the plunge and complete the level 2 electrical installation course from City and Guilds. My...
20K
Hey everyone, apologies if this is in the incorrect place. I want to find out what it is I need to do in order to complete my path to becoming a...
The final registration for the City & Guilds NVQ 2356-99 (Mature Candidate Assessment) will be on 31/12/2020. This means that we cannot enrol...
6K
Electrical Courses
