This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
P
Palmer James
Hi,
I have a Danfoss programmable thermostat. I would like to retrofit this with a smart wifi thermostat; the Ecobee 3.
Danfoss wiring manual: http://heating.danfoss.co.uk/PCMPDF/38161v01s7-06.pdf. Page 5-10
Ecobee 3 wiring manual: https://www.ecobee.com/wp-content/uploads/2013/12/ecobee3_InstallationGuide.pdf, page 11-16, 34-36
Please can you me know if it is compatible so that I can retrofit the Danfoss thermostat with the Ecobee 3? I have been told that this requires installation of a separate timeswitch to retrofit the Danfoss with the Ecobee 3 thermostat.
Hi,
This link is for a twin channel programmer not a programable thermostat.
Do you have a Combi boiler? If so then this will be okay on it's own. If you have a conventional system with a hot water tank then you will need some type of timer to control the hot water times.
Not a cat in hells chance!
Apart from the fact they are two different devices they also appear to be designed for two different countries. The danfoss is a standard British 2 channel programmer and the ecobee is a septic 24V thermostat
It's a [TABLE="width: 404"]
[TR]
[TD="class: xl65, width: 404"]Danesmoore 15/19 utility boiler. It's a conventional system with a water boiler.
What sort of timer would I need to control the hot water times?[/TD]
[/TR]
[/TABLE]
Seriously? You can't see any issue with connecting a 24V American stat to a UK 240V installation?
Okay Dave yes you're right I just briefly skipped through the instructions didn't spot it was 24 volts not 240 volts.
To the OP forget it it's not suitable for use in the UK. I would consider BG's hive system or similar.
I'm basically just looking for a smart wifi thermostat (as long as it's compatible and can be installed). Can you let me know which thermostats are compatible? By BG hive system I think you mean British Gas hive system
Nest or a salus IT500 are both possible options. As for fitting it as long as the electrician you employ has half a brain cell a simple domestic heating system should present no problem.
Yes I meant British Gas. With the hive you can control water and heating times through an app on your phone. It costs £199 fitted. With the nest system you can only control the heating so you would still need a timer for the water. Not sure about the Salus system Dave mentioned.
According to Amazon Salas IT500, although internet controlled, is not smart (does not store temp-time points to extrapolate a future pattern). This is key. NEST does but isn't NEST the same design as Honeywell?
Have a look at evohome , great system . We fit the base station with all our boiler installs and use it as a programmable room stat that can de added to as and when
Ok. Which thermostat is best for a 24V retrofit? Most do not say that Danfoss FS715si is compatible sadly
